I alter the settings view mode while reviewing the options, I was watching the view options and check inadvertently XML, and now only see XML code. As I fix it to see my index of ZoneMinder.
I only see this code;
<ZM_XML><GENERAL><RUNNING>1</RUNNING><PROTOVER>2</PROTOVER><FEATURESET>3</FEATURESET><VERSION>1.25.0</VERSION><CANSTR264/><GD>1</GD><FVCODEC>mjpeg</FVCODEC><FVTMT>20</FVTMT><USER>admin</USER><UID/><PERMS><STREAM>View</STREAM><EVENTS>Edit</EVENTS><CONTROL>Edit</CONTROL><MONITORS>Edit</MONITORS><DEVICES>Edit</DEVICES><SYSTEM>Edit</SYSTEM></PERMS><STATE>stop</STATE><STATE>restart</STATE></GENERAL><MONITOR_LIST><MONITOR><ID>1</ID><NAME>Moneda_906_Entrada</NAME><FUNCTION>Modect</FUNCTION><NUMEVENTS>0</NUMEVENTS><ENABLED>1</ENABLED><ZMC>1</ZMC><ZMA>1</ZMA><STATE>OK</STATE><WIDTH>320</WIDTH><HEIGHT>240</HEIGHT><PAGEOFF>0</PAGEOFF><EVENTS/></MONITOR><MONITOR><ID>2</ID><NAME>Moneda_906_Area_1</NAME><FUNCTION>Modect</FUNCTION><NUMEVENTS>0</NUMEVENTS><ENABLED>1</ENABLED><ZMC>1</ZMC><ZMA>1</ZMA><STATE>OK</STATE><WIDTH>320</WIDTH><HEIGHT>240</HEIGHT><PAGEOFF>0</PAGEOFF><EVENTS/></MONITOR></MONITOR_LIST></ZM_XML>
Salute from Chile.
Error and I plead guilty
Re: Error and I plead guilty (solved)
Into server/zm/index.php?skin=classic
and then I change the configuration and save.
I thought to reinstall everything.
