ZoneMinder failing to start as a service...
Posted: Thu Jun 14, 2012 1:01 am
Install appeared successful... I can get to ZoneMinder Control Panel with localhost/zm... However, I get nothing from the cam.
When trying to launch ZoneMinder as a service from the linux terminal, I get:
Starting ZoneMinder: Bareword "ZM_WEB_GROUP" not allowed while "strict subs" in use at /usr/share/perl5/ZoneMinder/Logger.pm line 557.
Compilation failed in require at /usr/share/perl5/ZoneMinder.pm line 34.
BEGIN failed--compilation aborted at /usr/share/perl5/ZoneMinder.pm line 34.
Compilation failed in require at /usr/bin/zmpkg.pl line 37.
BEGIN failed--compilation aborted at /usr/bin/zmpkg.pl line 37.
failure
Also, after setting up the camera in the Control Panel, then clicking "Probe", I'm getting:
Notice: Use of undefined constant ZM_V4L2 - assumed 'ZM_V4L2' in /usr/share/zoneminder/skins/classic/views/monitorprobe.php on line 30 Unable to probe network cameras, status is '127'
Does anyone have any ideas on how to fix this ???
Thank you in advance.
grpace
failure
grpace
