Page 1 of 1
unexpected $end inspite of short tags enabled
Posted: Thu Jun 14, 2012 1:20 pm
by obelix_a
I just installed zm on my gentoo x64.
Now, when trying to open the page I only get:
Parse error: syntax error, unexpected $end in /mnt/raid/data/Linux/www/localhost/htdocs/zoneminder/includes/functions.php on line 2437
As far as I found solutions by searching the forum I should enable the short tags in php.ini
But the default value is "On". Explicitly enabling doest not change anything...
any ideas?
thanks in advance
Obelix
Re: unexpected $end inspite of short tags enabled
Posted: Thu Jun 14, 2012 11:18 pm
by bb99
Did you check the second entry? There's more then one and it was the second value that fixed it for me but I got the main ZM screen but nothing else.
