Compro IP540 IP Cam PTZ Day & Night - Works up to 30FPS
francisuk22
Post by francisuk22 »
Hello all.
Just a quick post and that my compro ip540 the day & night ip network cam works like a charm.
System: Ubuntu Server 12.04 64 Bits.
Add another cam and input theses settings
Remote Protocol
HTTP
Remote Method
Simple
Remote Host Name
admin:password@YOUR IP540 IP ADDRESS
Remote Image Colours
24 bit colour
Remote Host Path
/mjpeg.cgi
Capture Width (pixels)
320
Capture Height (pixels)
240
Leave everything the same and save. :)
Enjoy!! :P
One thing i cant get to work yet is the PT so if anyone can get it to work, Post back :D Here are some features that might be interesting to someone to get a good stream from it.
This IP cam supports real-time H.264, MPEG-4 and MJPEG compression (Triple Codec)
Supports dual streams simultaneously
Image frame rate is up to 15 frames per second at 1280x1024 resolution
Smart motion detection
Web browser support via MJPEG mode (video only)
Proof that it works :)
Config, When add another Cam
Intel Dual Core 3.0GHz
1GB RAM
80GB HDD
