How to create hash value?
DrBrain
Post by DrBrain »
I'd like to use the zmu utility using an authentication hash instead of passing cleartext username/pass. Can you please let me know what kind of information the hash value should contain and which hash algorithm it's being used?
Thanks!
usersenior
Re: How to create hash value?
Post by usersenior »
function getAuthUser( $auth )
    if ( ZM_OPT_USE_AUTH && ZM_AUTH_RELAY == "hashed" && !empty($auth) )
        $remoteAddr = "";
        if ( ZM_AUTH_HASH_IPS )
            $remoteAddr = $_SERVER['REMOTE_ADDR'];
            if ( !$remoteAddr )
                Error( "Can't determine remote address for authentication, using empty string" );
                $remoteAddr = "";
        $sql = "select Username, Password, Enabled, Stream+0, Events+0, Control+0, Monitors+0, System+0, MonitorIds from Users where Enabled = 1";
       /* Create hash*/
       foreach ( dbFetchAll( $sql ) as $user )
            $now = time();
            for ( $i = 0; $i < 2; $i++, $now -= (60*60) ) // Try for last two hours
                $time = localtime( $now );
                $authKey = ZM_AUTH_HASH_SECRET.$user['Username'].$user['Password'].$remoteAddr.$time[2].$time[3].$time[4].$time[5];
                $authHash = md5( $authKey );
                if ( $auth == $authHash )
                    return( $user );
    Error( "Unable to authenticate user from auth hash '$auth'" );
    return( false );
DrBrain
Post by DrBrain »
Thanks for the reference.
If I interpret the source right, for my hash to be valid it should have been generated in the last 2 hours? So ZM's password hashing is not a plain "get plaintext, add salt, md5-it, store the hash in the db"-like algorithm?
Thanks!
usersenior
yes, but the hash don't is stored in db, this is send with that url .
e.g
zonminder/cgi-bin/nph-zms?mode=jpeg&monitor=18&scale=100&maxfps=5&buffer=1000&auth=bfd2cef9356b78d996781c5956c5f705&connkey=30037&rand=1341922224
DrBrain
Post by DrBrain »
Ok, I see.
This may be a little bit of a problem in my case then. I understand ZM's intention is that clear text password is not transmitted as such via HTTP, however my requirement in this case is that I do not even store the password anywhere at all. Obviously, to be able to generate the hash every two hours mean I do have to store the password of the user somewhere in the system originating the call to 'zmu'.
Thanks.
Paranoid
Post by Paranoid »
Its been quite a while since I've done anything with md5 but if I recall correctly text is processed in 64 byte chunks.
This means that if you can arrange for ZM_AUTH_HASH_SECRET.$user['Username'].$user['Password'] to be a multiple of 64 bytes then you can probably generate a hash without storing the user name or password.
MD5 is initialised as follows ( http://en.wikipedia.org/wiki/Md5 ):
var int h0 := 0x67452301
var int h1 := 0xefcdab89
var int h2 := 0x98badcfe
var int h3 := 0x10325476
So what you will have to do is run the md5 code with the initial 64 byte string and save the values of h0-h3. You can then use these as initialisation values to your own version of md5 and hash the $remoteAddr.$time[2].$time[3].$time[4].$time[5] part.
Overall, a very messy but possible solution.
