i now this is not a dead project but it seems a bit orphaned by now, i am using mastertheknife github version without problems with ffmpeg 0.10.3 but the source uses deprecated functions in 0.11.1 version and autotools check for libavcodec don't works either, here you can find the problems: L8ruqvk7 at pastebin <-- sorry i can't post links.
I have tried to find a bug tracker but i can't find it, after search the forums it seems development it is a bit stalled.
I am evaluating ZoneMinder to change 6 DVR a customer of mine have but i am a bit worried about the future of the project in the current form, maybe should we create a bug tracker and try to use mastertheknife github for future development, what do the people think about this? masterthenike what do you think about that?
Regards,
Miguel Angel.
problem compiling with ffmpeg 0.11.1 and future development
Re: problem compiling with ffmpeg 0.11.1 and future developm
i have spoken in irc channel with some users and developers, it seems many people are using mastertheknife version waiting for Phil to release ZM2, development it's a bit slow but progressing anyway so sorry for the noise.
