Just installed Zoneminder from the Ubuntu 12.04 package version 1.25. For whatever reason, Chrome/Safari/Firefox Javascript is complaining that there is no "Object.clone" function in skin.js when I try to add a monitor. What is odd is that when I installed previously with source, it didn't have this problem and the skin.js files are identical. Is something not getting loaded? I can't find the Object.clone function defined anywhere.
Thank you in advance.
Object.clone javascript not working?
Re: Object.clone javascript not working?
Found the problem.
Zoneminder refers to mootools files under /javascript, which translates to /usr/share/zoneminder/javascript, when Ubuntu/Debian actually installs these into /usr/share/javascript. Putting an alias into your webserver config for /javascript -> /usr/share/javascript will fix the problem. Make sure your browser caches are flushed, otherwise it may not load the proper files again.
Thanks, that solved my problem.
The installation of ZM is a hell
