Page 1 of 1
Image::Overlay patch
Posted: Sun Aug 05, 2012 6:06 am
by arash
here is patch for Image::Overlay() function :
Index: zm_image.cpp
--- zm_image.cpp	(revision 3688)
+++ zm_image.cpp	(working copy)
@@ -711,12 +711,12 @@
 void Image::Overlay( const Image &image, int x, int y )
-	if ( !(width < image.width || height < image.height) )
+	if ( width < image.width || height < image.height )
         Panic( "Attempt to overlay image too big for destination, %dx%d > %dx%d", image.width, image.height, width, height );
-	if ( !(width < (x+image.width) || height < (y+image.height)) )
+	if ( width < (x+image.width) || height < (y+image.height) )
         Panic( "Attempt to overlay image outside of destination bounds, %dx%d @ %dx%d > %dx%d", image.width, image.height, x, y, width, height );
Re: Image::Overlay patch
Posted: Sun Aug 05, 2012 8:40 am
by Christo
Hello Arash,
I am curious about your post..
I am looking for a method to get an overlay on one of my camera images.
Could you please explain what update does and how to implement this!?
Kind regards and thanks in advance, Christo
Posted: Sun Aug 05, 2012 9:49 am
by arash
hello Christo,
existing Overlay function doesn't work at all.
if you look closely at the two 'if' conditions you can see they're reverse.
the rest of the function is fine. I currently use it for image overlaying and it works without a problem.
generally you can use "patch" utility to apply diffs. but for this case you can simply remove the two not ('!') operation from first two "if" statements
here is the patched version of the function :
	if ( !(colours == image.colours) )
        Panic( "Attempt to partial overlay differently coloured images, expected %d, got %d", colours, image.colours );
	int lo_x = x;
	int lo_y = y;
	int hi_x = (x+image.width)-1;
	int hi_y = (y+image.height-1);
	if ( colours == 1 )
	    unsigned char *psrc = image.buffer;
		for ( int y = lo_y; y <= hi_y; y++ )
			unsigned char *pdest = &buffer[(y*width)+lo_x];
			for ( int x = lo_x; x <= hi_x; x++ )
				*pdest++ = *psrc++;
	else if ( colours == 3 )
			unsigned char *pdest = &buffer[colours*((y*width)+lo_x)];
				*pdest++ = *psrc++;
				*pdest++ = *psrc++;
				*pdest++ = *psrc++;
Posted: Mon Aug 06, 2012 2:38 pm
by Christo
Hello Arash,
OK, Ill get your point now!!
I have been searching within the WIKI and this forum but found no additional information about how to apply such an overlay.
I asume you did figure this out by yourself? Or was I just looking at the wrong place?
Maybe you can point me out how?
Kind regards and Thanks, Christo
