Axis 2400 missing feed, suggestions?
Posted: Fri Aug 17, 2012 11:47 am
Hi and thanks for reading.
I got two Axis 2400 video encoders, but one of them seems to be a bit broken. Both have latest firmware (2.34) It works for a while, but then it stops broadcasting video. I have tried to switch input but no difference. The web interface works fine, though. Just no image. I was wondering if there is some component that breaks and creates these kind of symptoms or some other kind of fix. Any suggestions for a fix would be welcome as I'm on a tight budget
