problem reproduction video
maliju
Post by maliju »
Hi all!
i am use zoneminder 1.25.0 on ubuntu server 12.04
I need to record video from camers in raid0 . This raid created on separate disks, and mounted in /mnt
I pointing Options -> patchs -> DIR_EVENTS "/mnt/events" , zoneminder begins to record video with camers.
If you view the video, in the logs an error : "Can't open /usr/share/zoneminder//mnt/events/3/12/08/20/16/21/35/001-capture.jpg: No such file or directory"
Zoneminder add /mnt/events/ to default path "/usr/share/zoneminder/" . How it fix?
Christo
Re: problem reproduction video
Post by Christo »
maliju wrote:Hi all!
Hello maliju,
I think you should search within previous post..so I did..
http://www.zoneminder.com/forums/viewto ... ory#p56438
Kind regards, Christo
