Hi All
Im using ZM 1.24.4 .
while clicking on the events for any camera ( I've configured many types of cams ranging gtom MJPEG to H.264) , I dont see the video link, to export the event as a video.
Kindly help
Regards
Prasad
No Video link found
Re: No Video link found
Enable opt_ffmpeg in options.
Thanks carrrier82.
after enabling the opt_ffmpeg option, i can see the link, but when i try to generate the video, it fails to generate.
I restarted zoneminder after modifying the options.
Hope you can guide.
Regards
Prasad
Hope you can guide.
Regards
Prasad
You do have ffmpeg installed, right? What do the logs say?
