Can't get the cameras work
Timmpann
Post by Timmpann »
Hi! I have set up ZoneMinder on my Linux server and everything except the cameras works. When I looking at the camera it's just some green buggy thing.
Copy/paste the links to see the images. The forum don't accept my links. The website is safe, its my own website.
Camera: bendrin.se/images/zm_camera_fail.png
Sorce options: bendrin.se/images/zm_camera_source.png
Does anyone know what the problem is and how to fix it? :)
Carrier82
Re: Can't get the cameras work
Post by Carrier82 »
What kind of cameras are those? 250 by 250 resolution sounds odd. Mjpg streamer usually works if video4linux doesn't. Palette is unlikely jpeg?
Timmpann
Post by Timmpann »
Carrier82 wrote:What kind of cameras are those? 250 by 250 resolution sounds odd. Mjpg streamer usually works if video4linux doesn't. Palette is unlikely jpeg?
Its just normal USB cameras. I don't know how big resolution the cameras have. But 250x250 is the size that i want the image to be shown at.
Carrier82
Post by Carrier82 »
That might require some kind of rescaling and could be difficult. You should use a resolution supported by the camera.
Timmpann
Post by Timmpann »
Carrier82 wrote:That might require some kind of rescaling and could be difficult. You should use a resolution supported by the camera.
Now i have the right resolution. 320x240, but I have the same problem with the green flicker image.
Carrier82
Post by Carrier82 »
Yes. The pallette is propably wrong, but I haven't had success with ZM and usb webcams using ZM's own v4l/v4l2 implementation. If you can see the webcams with cheese or some other linux program, then mjpg_streamer (google) should do the trick. My Logitech web cam did the same green image until I circulated the stream through mjpg_streamer.
Timmpann
Post by Timmpann »
Ok, thanx for the help. But i gived up. It's too much job for a just for fun thing. :P
