Having zoneminder automatically start in running state
GrangerTech
Post by GrangerTech »
I have a zoneminder set up on ubuntu 10.04. Zoneminder is installed and the process is running at boot however when I open the zm console it says zoneminder is stopped. How do I make it so zoneminder is in the running state automatically at boot?
It needs to be automatically done because this computer isnt constantly checked...its used only for zoneminder.
PacoLM
Re: Having zoneminder automatically start in running state
Post by PacoLM »
Install the package rcconf or chkconfig, then select the zm package to be started at boot.
Carrier82
Post by Carrier82 »
At least in ubuntu 12.04 you need to add 'sleep 15' to /etc/init.d/zoneminder before line 'zmfix -a' to make sure mysqld starts before zoneminder. If this isn't done, zoneminder won't start at boot even if it's supposed to.
