Help with Buffer overrun errors
Posted: Wed Sep 12, 2012 5:58 pm
I have the following configuration, and i cannot figure out how to record continuisly without generating buffer overrun errors listed below.
Config:
Ubuntu 12.04 64-bit runnign vmware workstation 9.0
Zoneminder 1.25 running in vm, on ubuntu 12.04 64-bit.
i5 CPU, 16gb ram, dual SSD's, 3TB storage
Nothing else running in the VM or host system of consequence
16gb system ram, 13.5gb allocated to VM
sysclt set to recommendations of memory script listed elsewhere on this board:
kernel.shmall = 3462163
kernel.shmmax = 12762917630
fs.file-max = 100000
vm.swappiness = 1
vm.vfs_cache_pressure = 25
1 camera, set to record, 20fps and 1280x1080 resolution. buffer set at 250 frames, 25 pre, 100post images
Error: Buffer overrun at index 40, image 2040, slow down capture, speed up analysis or increase ring buffer size
I have tried everything I can think of and regardless, I end up getting this error after a few minutes of continuis recording.
Any help would be appreciated.
Config:
vm.swappiness = 1
