I ran out of space, now I can't start ZM
baekmark
Post by baekmark »
Hi list,
I made a similar post on Monday, But I haven't got any reply or solution, so I'm trying with a different headline!
The issue is still the same!
my Zoneminder ran out of diskspace, and now I can't start ZM. I'm running V1.25.0 on a 64 bit Ubuntu 11.04. Before this incident, the server has been running for many month!
When I try to start via init.d I get this:
root@npczm:~# /etc/init.d/zm start
Starting ZoneMinder: Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 150.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 149.
Bareword "ZM_DYN_DB_VERSION" not allowed while "strict subs" in use at /usr/local/bin/zmpkg.pl line 151.
Execution of /usr/local/bin/zmpkg.pl aborted due to compilation errors.
failure
root@npczm:~#
I have some 116 M available space!
Right now all space is being used under the /var/www/zm directory, and I kind of don't want to remove any files before ZM is running again
Any help is appreciated
BR
Lars
dante
Re: I ran out of space, now I can't start ZM
Post by dante »
Hi
I had the same error. The error is because some of the records from the Config table (from the mysql zm database) were deleted.
I compared this table with the original and detected that the records with the id greater than 201 do not exists.
So, I just copied those records, start the zoneminder service and everything begins to works as expected.
Dante
thomas1977
Post by thomas1977 »
Hi @ all,
Having the same problem here after disk running full. I dont know how to compare the Config tables. Compare with what?
How can I restore my installation?
thanks a lot
thomas1977
