The error shows exactly the below. I am recording to a samba share and the drive has 66% full, and the ZM gui also shows same. I edited the symlink to point to the share drive, and left the options in the GUI alone.
Anyone else see this problem?
Can't mkdir events/1/12/09/14/06: No space left on device
ZM reports "no space left on device"
- punch-card
Re: ZM reports "no space left on device"
Did you try su'ing to the user that is running your apache server? (maybe apache?)
See if this user can write to the mounted share on your server from the OS mount?
Best Regards
Mike
Mike
Yep - www-data can write to the share no problem
Can you please post the output of the following command:
df
