Montage blank....
Montage blank....
ZM 1.19.1, two remote cameras at 640x480. Carmera's are working fine but the Montage window pops up with a small window, without any video in it. Montage buttons are in the window but now video. Any suggestions on how to troubleshoot?
- zoneminder
- Site Admin
- Contact:
Re: Montage blank....
Hi Scott,
The only thing I can think of is if the monitors are set to have no function, otherwise they should appear. I don't know if I'm exactly understanding your description of the window though. Is individual streaming working ok?
Phil,
Phil,
Both Camera's are set to modect and functioning fine. It's Montage that is not working. These are both using video.cgi in the remote path. Another fun thing I noticed also is that we viewing events while in the camera ,previous button go to the next numbered event rather that the previous numbered event. Next button work the opposite.
- zoneminder
- Site Admin
- Contact:
I'm still not 100% sure of what you see in the Montage window, is it just a tiny window or the size that it would be to display two images? The path to the remote image shouldn't make any difference. One thing to check is in the Options->Web area there are several settings relating to Montages, check that they are all set to something sensible.
The behaviour of the Next and Prev buttons is not a bug, it's a requested feature. It is explained more in the changelog in the README, as well as in a couple of posts here but in essence, the Next button will take you to the 'next' event in whatever order the events are listed in parent event list. So if you sort by ascending duration the Next event is the next biggest one, if you sort by ascending time then it will be the next event in time. The default order is descending time so the 'next' event is the one below it in the list, ie the one before it.
Phil,
Phil,
Tiny Montage window, option setting were set to 2 and 3, I set them to 0 and it works now thanks.
-Scott
-Scott
