PERL Script to detect daylight and start/stop cameras
jonathancnewcomb
Post by jonathancnewcomb »
I have 2 cameras monitoring my grandmothers house which do not have night capabilities, after receiving multiple events for cars driving by and wasting a large amount of hard disk space, I wrote the following using perl to calculate the sunrise and sunset and to enable/disable the cameras accordingly. This was a quick write, so please constructive criticism only:
You will need the perl module DateTime::Event::Sunrise
sudo cpan
install DateTime::Event::Sunrise
The following is the perl script, please modify parameters as defined below
#! /usr/bin/perl
	use strict;
	use warnings;
	use DateTime;
	use DateTime::Event::Sunrise;
	my @cams = qw(1 5); # space delimited monitor id's
	my $username = "admin"; # administrative username
	my $password = "password"; #admin password
	my $latt = 'xx.xxxx'; # Lattitude from google
	my $long = 'xx.xxxx'; # Longitude from google
	my $alt = '-6';
	my $tz = 'America/Chicago'; # Timezone can be found (in ubuntu) by 'cat /etc/timezone'
	my $state_directory = "/opt/camera_scripts/"; # working directory for the state files
	sub Log{
		my $message = $_[0];
		my $timestamp = `date +[\%Y-\%m-\%d\\ \%H:\%M:\%S]`;
		chomp($timestamp);
		open(LOG, ">> /var/log/camstopper.log");
		print LOG $timestamp." ".$message."\n";
		close(LOG);
	my $today = `date +\%Y,\%m,\%d`;
	chomp($today);
	my @date = split(",", $today);
	my $dt = DateTime->new( year => $date[0], month => $date[1], day => $date[2], time_zone => $tz);
	my $sunrise = DateTime::Event::Sunrise->sunrise(longitude => $long, latitude => $latt, altitude => $alt, iteration => 1);
	my $sunset = DateTime::Event::Sunrise->sunset(longitude => $long, latitude => $latt, altitude => $alt, iteration => 1);
	my $rise = $sunrise->next($dt);
	my $set = $sunset->next($dt);
	my @rise_parts = split("T", $rise);
	my @set_parts = split("T", $set);
	my $rise_time = $rise_parts[1];
	my $set_time = $set_parts[1];
	my $cur_time = `date +\%H:\%M:\%S`;
	chomp($cur_time);
	foreach my $cam(@cams){
		my $cam_file = $state_directory.$cam;
		if($cur_time gt $rise_time && $cur_time lt $set_time){
			# After sunrise
			unless(-e $cam_file){
				Log("Cam file not found. Sunrise at ".$rise_time."! Setting camera ".$cam." to enable");
				open(CAMFILE, "> $cam_file");
				print CAMFILE 1;
				`zmu -m $cam -E -U $username -P $password`;
				close(CAMFILE);
			}else{
				open(CAMFILE, "< $cam_file");
				my @file = <CAMFILE>;
				close(CAMFILE);
				unless($file[0] == 1){
					Log("Sunrise detected (Rise time at ".$rise_time.")! Setting cam ".$cam." to enable");
					print CAMFILE 1;
					close(CAMFILE);
		}else{
			# After sunset
				Log("Cam file not found. Sunset at ".$set_time."! Setting camera ".$cam." to disable");
				print CAMFILE 0;
				`zmu -m $cam -D -U $username -P $password`;
				close(CAMFILE);
			}else{
				close(CAMFILE);
				unless($file[0] == 0){
					Log("Sunset detected (Set time at ".$set_time.")! Setting cam ".$cam." to disable");
					print CAMFILE 0;
					close(CAMFILE);
You will need to create the file "/var/log/camstopper.log" with write permissions of the user that will run the script. I set a cron job to run every 5 minutes.
