I am at present trying to set up a dedicated box that is currently running Ubuntu 10.04 and Zoneminder, 1.24.x there is a Geovision GV650 capture card installed also an Axis 241Q video server also attached via router, now the problems that I am seeking help with is as of yet I can only get Zoneminder to monitor 1 stream of the four available from the Axis server and only if I turn off password protection to the Axis server, where I am a little confused is that each of the four streams has the same IP address and it is only the channel No that is different IE 1-4, so how do I configure Zoneminder to monitor all four channels separately and still use the password protection on the Axis server.
Secondly the Geovision GV650 card doesn't seem to be recognised at all even though it has a BT878 chip, I have tried different things to get it working but due to my lack of experience working with Linux I didn't have much luck I have also tried a couple of the how to's but I don't really know what I am doing so was hoping for some help through this forum.
Thirdly when using a web cam with the system I can only seem to get a blue screen or a red screen depending on the settings used.
I am keen to get this system working so any assistance would be very much appreciated.
Hopeful of a favourable response.
Martin
