Foscam control problem with incorrect port number being used
macsrthebomb
Post by macsrthebomb »
Ubuntu 12.04 64bit
Zoneminder 1.25.0
Hello, I have numerous Foscam FI8918w cameras, and every thing work except having a real headache with getting the controls to work correclty. I have created the control file, etc. and am able to get to the camera no problem. I just can't control it. I think I found the problem, but don't know where to remedy it. I use port 4001 (instead of 80) to access the camera. In the source setting, i specify port 4001. I finally see in the zmcontrol.log file showing port 80 and not 4001. Can someone help me figure this out?
09/22/12 01:14:50.467359 zmcontrol[22782].ERR [Error check failed:'500 Can't connect to 172.19.1.12:80 (Connection refused)']
09/22/12 01:14:50.829396 zmcontrol[22782].ERR [Error check failed:'500 Can't connect to 172.19.1.12:80 (Connection refused)']
alan@Ubuntu:/var/log/zm$
Thanks in advance,
Alan
waldrondigital
Re: Foscam control problem with incorrect port number being
Post by waldrondigital »
I too am having problems with the controls, but it sounds like you are doing better than I am.
On the control tab for your camera, in the "control device" input box, do you have "172.19.1.12:4001"?
It should work with the above looking at the script, as it just passes whatever you put in there. Report back and we'll go from there.
macsrthebomb
Well, I didn't, but sure thought I tried it (when I started to add the :4001, it showed in the list of previous attempts, so I know I tried it before, but this time it is WORKING!!!
Thank you. They should add a field for the port number for the control address.
Alan
waldrondigital
Can you share where you got your control script? I'm having a problem with mine and figured I'd compare notes.
