Ok,
I am making terrific progress.
I now have clean configure and think I am close to having this 1.19.1 working.
However, I am not getting any image (Broken Link) when looking at the monitor window.
I am using an Axis 2420 2.40. The monitor is obviously configured as remote, the source is the camera’s IP, and the path is /axis-cgi/jpg/image.cgi
When I issue a wget, things look good to me:
[wmoore /tmp]$ wget -S http://192.168.0.50/axis-cgi/jpg/image.cgi
--19:24:28-- http://192.168.0.50/axis-cgi/jpg/image.cgi
=> `image.cgi'
Connecting to 192.168.0.50:80... connected.
HTTP request sent, awaiting response...
1 HTTP/1.0 200 OK
2 Connection: Close
3 Server: Camd
4 Content-Type: image/jpeg
[ <=> ] 180,973 4.79M/s
19:24:28 (4.79 MB/s) - `image.cgi' saved [180973]
I think this clue is in the zmdc.log file:
Starting pending process, zmc -m 1
'zmc -m 1' starting at 04/04/02 21:18:40, pid = 24653
'zmc -m 1' started at 04/04/02 21:18:40
'zmc -m 1' crashed at 04/04/02 21:18:40, exit status 255
'zmc -m 1' starting at 04/04/02 21:33:40, pid = 25272
'zmc -m 1' started at 04/04/02 21:33:40
'zmc -m 1' crashed at 04/04/02 21:33:40, exit status 255
The above messages are repeated over and over again. I have searched the forums, just cant seem tim find the reason for the failures. I need another nudge.
Any help would per appreciated.
-WAM
Re: 'zmc -m 1' crashed at 04/04/02 21:33:40, exit status 255
Additional Info:
from /var/log/messages:
Apr 2 21:48:40 Security zmc-m1[25899]: INF [Debug Level = 0, Debug Log = ]
Apr 2 21:48:40 Security zmc-m1[25899]: ERR [Can't shmget: Invalid argument]
Great - someone else with a 2420....I am having a pile of fun trying to get mine to work.
I fixed all of the shmgets by:
1) Rebooting to clear everything out (clever people could probably do this without rebooting)
2) Setting my shmmax to 300 Mbytes. You could also reduce the frame buffer to 5 frames to see if this is the problem.
3) Starting zmpkg.pl from the commant line as root - I am getting permissions errors if I try and start from the browser
If you have done all of that, then you are at the limit of my expertise. Mine is still crashing - but there are a load of jpeg errors, which you are not getting.
Rupert
Rupert
