How to get control type if your source type is FFMPEG
cgprasad
Post by cgprasad »
Hi All
Recently wjile working out with Foscam FI8620 and Dlink DCS-5635 I found out that if you mentioned the "source type" of these cameras as "ffmpeg" instead of "remote" , then you won't get the drop down of control scripts on the "control type".
Does anyone have any idea to get the control scripts of these enabled. Some of these cams do not have MJPG and support only H.264.
Any help would be appreciated.
Prasad
