I bought one of theses from my brother as hes gone onto Xbox 360
So i had a play and taken it out since theres no info on zoneminder (Due to being new)
Well lucky me i did and theres no need to install drivers its just a plug in and play and setup
DON'T!! make the the capture width and height any higher then 640 by 480 or you will loose video!
YouTube Demo
http://www.youtube.com/watch?v=Q8N5WufdCIY
Taken from the wikipedia on PlayStation Eye found at http://en.wikipedia.org/wiki/PlayStation_Eye
The PlayStation Eye is capable of capturing standard video with frame rates of 60 hertz at a 640×480 pixel resolution, and 120 hertz at 320×240 pixels, which is "four times the resolution" and "two times the frame-rate" of the EyeToy, according to Sony Higher frame rate, up to 320x240@187 or 640x480@75 fps, can be selected by specific applications (Freetrack and Linuxtrack)
PlayStation Eye Camera 640x480@30fps Works
Intel Dual Core 3.0GHz
1GB RAM
80GB HDD
1GB RAM
80GB HDD
