installation problem with cpanel
mario99
Post by mario99 »
Hello, I am unable to install ZoneMinder on a VPS with cpanel.
If I do the clean install with CentOS 6. correct functioning.
But if I do the installation of cpanel / whm and then install ZoneMinder not work.
Install them but not shown xxx.xx.xxx.xxx/zm/index.php page in the main directory of the VPS. makes a 404 page not found.
Any idea of installing ZoneMinder + cpanel?
Sorry for my English.
thanks
usersenior
Re: installation problem with cpanel
Post by usersenior »
mario99 wrote:Hello, I am unable to install ZoneMinder on a VPS with cpanel.
thanks
hello mario99
this is because you have to set the correct path in apache for zm, create a domain for your ZM and then go in / usr / local / apache / conf / httpd.conf and place in the document root path to your zm not forget later add the User of this group of users in the field of zm
mario99
Post by mario99 »
thanks
hello mario99
Hello Usersenior , When I create an installation of ZoneMinder, as I can do to be installed on a subdomain account?
The tutorials make installation at the root of the server's IP, but I want to do the installation within a specific account, as in I can not access the root once installed cpanel.
I have little knowledge in installation.
thanks for your reply.
