Dumb
I can no longer stream in single camera view. (when you clink on the name of a camera) This only occurs in IE10. It will stream in firefox it will not stream in chrome. In IE and Chrome all you gotta do is click the image that is show that is static and it will give you the next frame. Click really fast and you get a video. My guess is a flash/java update or something screwed this up. ZM is OK, the browsers are busted. My Droid works just fine, another laptop I have exhibits the exact same issue.
Montage works fine.
This started just 10 minutes ago and I have rebooted everything, problem still exists.
Anybody seen this before?
thanks,
Jerry
