Page 1 of 1
no make zoneminder on centos 6.3 64 bit (1.24.4 version)
Posted: Fri Oct 19, 2012 9:27 am
by mobil1
error is
zm_file_camera.cpp:93 error: variable or field 'av_free_packet' declared void
zm_file_camera.cpp:93 error: 'AVPacket' was not declared in this scope
zm_file_camera.cpp:93 error: 'pkt' was not declared in this scope
ffmpeg work. he was make of git of official site...
please help.
Re: no make zoneminder on centos 6.3 64 bit (1.24.4 version)
Posted: Fri Oct 19, 2012 10:31 am
by mobil1
new error before install ffmpeg 0.6.5
zm_ffmpeg.h:33:2: error: #error "No location for avutils.h found"
zm_ffmpeg.h:40:2: error: #error "No location for avcodec.h found"
zm_ffmpeg.h:47:2: error: #error "No location for avformat.h found"
zm_ffmpeg.h:55:2: error: #error "No location for swscale.h found"
In file included from zm_stream.h:27,
from zm_event.h:39,
from zm_zone.h:27,
from zm_monitor.h:26,
from zmc.cpp:28:
zm_mpeg.h:43: error: use of enum 'PixelFormat' without previous declaration
zm_mpeg.h:44: error: ISO C++ forbids declaration of 'AVOutputFormat' with no type
zm_mpeg.h:44: error: expected ';' before '*' token
zm_mpeg.h:45: error: ISO C++ forbids declaration of 'AVFormatContext' with no type
zm_mpeg.h:45: error: expected ';' before '*' token
zm_mpeg.h:46: error: ISO C++ forbids declaration of 'AVStream' with no type
zm_mpeg.h:46: error: expected ';' before '*' token
zm_mpeg.h:47: error: ISO C++ forbids declaration of 'AVFrame' with no type
zm_mpeg.h:47: error: expected ';' before '*' token
zm_mpeg.h:48: error: ISO C++ forbids declaration of 'AVFrame' with no type
zm_mpeg.h:48: error: expected ';' before '*' token
zm_mpeg.h:49: error: ISO C++ forbids declaration of 'uint8_t' with no type
zm_mpeg.h:49: error: expected ';' before '*' token
zm_mpeg.h:65: error: 'uint8_t' has not been declared
make[3]: *** [zmc.o] Error 1
Posted: Fri Oct 19, 2012 1:11 pm
by mobil1
new error
make  all-recursive
make[1]: Entering directory `/root/ZoneMinder-1.24.4'
Making all in src
make[2]: Entering directory `/root/ZoneMinder-1.24.4/src'
g++ -DHAVE_CONFIG_H -I. -I..  -I/usr/include -I/usr/include -Wall -Wno-sign-compare -fno-inline -I/usr/include   -D__STDC_CONSTANT_MACROS -MT zm_ffmpeg_camera.o -MD -MP -MF .deps/zm_ffmpeg_camera.Tpo -c -o zm_ffmpeg_camera.o zm_ffmpeg_camera.cpp
zm_ffmpeg_camera.cpp:105:44: error: missing binary operator before token "("
In file included from zm_ffmpeg_camera.cpp:24:
zm_ffmpeg_camera.h:39: error: ISO C++ forbids declaration of ‘AVFormatContext’ with no type
zm_ffmpeg_camera.h:39: error: expected ‘;’ before ‘*’ token
zm_ffmpeg_camera.h:41: error: ISO C++ forbids declaration of ‘AVCodecContext’ with no type
zm_ffmpeg_camera.h:41: error: expected ‘;’ before ‘*’ token
zm_ffmpeg_camera.h:42: error: ISO C++ forbids declaration of ‘AVCodec’ with no type
zm_ffmpeg_camera.h:42: error: expected ‘;’ before ‘*’ token
zm_ffmpeg_camera.h:44: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_ffmpeg_camera.h:44: error: expected ‘;’ before ‘*’ token
zm_ffmpeg_camera.h:45: error: ISO C++ forbids declaration of ‘AVFrame’ with no type
zm_ffmpeg_camera.h:45: error: expected ‘;’ before ‘*’ token
zm_ffmpeg_camera.cpp: In constructor ‘FfmpegCamera::FfmpegCamera(int, const std::string&, int, int, int, int, int, int, int, bool)’:
zm_ffmpeg_camera.cpp:35: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:37: error: ‘mCodecContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:38: error: ‘mCodec’ was not declared in this scope
zm_ffmpeg_camera.cpp:40: error: ‘mRawFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:41: error: ‘mFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp: In destructor ‘virtual FfmpegCamera::~FfmpegCamera()’:
zm_ffmpeg_camera.cpp:46: error: ‘mFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:46: error: ‘av_freep’ was not declared in this scope
zm_ffmpeg_camera.cpp:47: error: ‘mRawFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:51: error: ‘sws_freeContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:54: error: ‘mCodecContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:56: error: ‘avcodec_close’ was not declared in this scope
zm_ffmpeg_camera.cpp:59: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:61: error: ‘av_close_input_file’ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function ‘void FfmpegCamera::Initialise()’:
zm_ffmpeg_camera.cpp:78: error: ‘AV_LOG_DEBUG’ was not declared in this scope
zm_ffmpeg_camera.cpp:78: error: ‘av_log_set_level’ was not declared in this scope
zm_ffmpeg_camera.cpp:80: error: ‘AV_LOG_QUIET’ was not declared in this scope
zm_ffmpeg_camera.cpp:80: error: ‘av_log_set_level’ was not declared in this scope
zm_ffmpeg_camera.cpp:82: error: ‘av_register_all’ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::PrimeCapture()’:
zm_ffmpeg_camera.cpp:94: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:94: error: ‘av_open_input_file’ was not declared in this scope
zm_ffmpeg_camera.cpp:95: error: ‘errno’ was not declared in this scope
zm_ffmpeg_camera.cpp:98: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:98: error: ‘av_find_stream_info’ was not declared in this scope
zm_ffmpeg_camera.cpp:99: error: ‘errno’ was not declared in this scope
zm_ffmpeg_camera.cpp:103: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:108: error: ‘CODEC_TYPE_VIDEO’ was not declared in this scope
zm_ffmpeg_camera.cpp:118: error: ‘mCodecContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:118: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:121: error: ‘mCodec’ was not declared in this scope
zm_ffmpeg_camera.cpp:121: error: ‘avcodec_find_decoder’ was not declared in this scope
zm_ffmpeg_camera.cpp:125: error: ‘mCodec’ was not declared in this scope
zm_ffmpeg_camera.cpp:125: error: ‘avcodec_open’ was not declared in this scope
zm_ffmpeg_camera.cpp:129: error: ‘mRawFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:129: error: ‘avcodec_alloc_frame’ was not declared in this scope
zm_ffmpeg_camera.cpp:132: error: ‘mFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:135: error: ‘PIX_FMT_RGB24’ was not declared in this scope
zm_ffmpeg_camera.cpp:135: error: ‘avpicture_get_size’ was not declared in this scope
zm_ffmpeg_camera.cpp:138: error: ‘AVPicture’ was not declared in this scope
zm_ffmpeg_camera.cpp:138: error: expected primary-expression before ‘)’ token
zm_ffmpeg_camera.cpp:138: error: ‘avpicture_fill’ was not declared in this scope
zm_ffmpeg_camera.cpp:141: error: ‘SWS_BICUBIC’ was not declared in this scope
zm_ffmpeg_camera.cpp:141: error: ‘sws_getCachedContext’ was not declared in this scope
zm_ffmpeg_camera.cpp: In member function ‘virtual int FfmpegCamera::Capture(Image&)’:
zm_ffmpeg_camera.cpp:159: error: ‘AVPacket’ was not declared in this scope
zm_ffmpeg_camera.cpp:159: error: expected ‘;’ before ‘packet’
zm_ffmpeg_camera.cpp:163: error: ‘mFormatContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:163: error: ‘packet’ was not declared in this scope
zm_ffmpeg_camera.cpp:163: error: ‘av_read_frame’ was not declared in this scope
zm_ffmpeg_camera.cpp:172: error: ‘mCodecContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:172: error: ‘mRawFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:172: error: ‘avcodec_decode_video2’ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: ‘mRawFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: ‘mCodecContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: ‘mFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:182: error: ‘sws_scale’ was not declared in this scope
zm_ffmpeg_camera.cpp:188: error: ‘mCodecContext’ was not declared in this scope
zm_ffmpeg_camera.cpp:188: error: ‘mFrame’ was not declared in this scope
zm_ffmpeg_camera.cpp:193: error: ‘av_free_packet’ was not declared in this scope
make[2]: *** [zm_ffmpeg_camera.o] Error 1
make[2]: Leaving directory `/root/ZoneMinder-1.24.4/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/ZoneMinder-1.24.4'
make: *** [all] Error 2
Posted: Tue Oct 23, 2012 11:45 am
by mobil1
thx, i am solved the problem myself.
Posted: Wed Mar 06, 2013 2:13 pm
by holdupmaster
Hi there,
I have this same issue and am convinced it is something straight forward but can't seem to fix it. How did you fix it in the end?
