Thanks for the help
Reality check (just in case) please ...river100 wrote:if you haven't found the solution yet, you have to,
stop ZM
copy the events dir to the location you want and then add or replace a symlink
to that location. it really depends on what distro you used and how ZM
was installed. some have symlinks and some installs use a real events folder.
you may need to rename or delete the original events folder
i usually rename them in case i mess up.
the best way to find a how to is search for add hard drive for event storage
