Another Shared Memory problem
Nemrtvej
Post by Nemrtvej »
Hello, I've installed ZM several weeks ago and from then, I am still fighting with error message
zmwatch[494].ERR [Can't get shared memory id '7a6d0001', 1: No such file or directory]
Yes, I've already tried to google it, all responses mentioned using commands
# echo 1073741824 >/proc/sys/kernel/shmmax
# echo 1073741824 >/proc/sys/kernel/shmall
and making those changes persistent via /etc/sysctl.conf. I've already tried it without luck.
My system is running Debian GNU/Linux 6.0.5 (squeeze), kernel version 2.6.32-5-amd64.
I am using Zoneminder 1.24.2.
ipcs -l output:
------ Shared Memory Limits --------
max number of segments = 4096
max seg size (kbytes) = 1048576
max total shared memory (kbytes) = 4294967296
min seg size (bytes) = 1
------ Semaphore Limits --------
max number of arrays = 128
max semaphores per array = 250
max semaphores system wide = 32000
max ops per semop call = 32
semaphore max value = 32767
------ Messages: Limits --------
max queues system wide = 15979
max size of message (bytes) = 8192
default max size of queue (bytes) = 16384
Please, do you have some idea, how to fix it?
bb99
Re: Another Shared Memory problem
Post by bb99 »
Your ERR message doesn't have to mean that you have a shared memory issue. I suggest disabling all but one monitor and adjusting the camera to output 320*240 and then adjust the settings in ZM to the same (assuming IP monitor, for capture card just adjust ZM). Back to your ERR message: it can mean simply that there is nothing stored in shared memory to retrieve which is what I'm guessing is your cause.
