Page 1 of 1
camera streams 30 seconds behind realtime
Posted: Sat Nov 03, 2012 7:11 pm
by allrightname
When view a camera stream via the console I get a good stream but it is around 30 seconds behind real-time. When I look at the camera's stream directly (skipping zoneminder) I see a real-time stream. Anyone know how I can fix this? The camera is a foscam clone and I'm using zoneminder svn rev 3711.
Re: camera streams 30 seconds behind realtime
Posted: Thu Nov 08, 2012 5:43 pm
by gregom
I have this problem on a specific model of Toshiba indoor camera... The only way I could fix it was to set the FPS on the camera itself, and set the FPS for that camera in ZM to blank, or null, just don't put in anything. Give that a try...
Posted: Fri Nov 09, 2012 3:20 pm
by allrightname
I had mine set to 5 fps during normal operation via zoneminder. I've set it back to blank and we'll see what happens. Thanks for your input.
Posted: Thu Feb 07, 2013 7:54 pm
by allrightname
Setting the FPS back to blank corrected my issue.
