zm not work ubuntu 12.10
starwolf
Post by starwolf »
i can login but
The requested URL /zm/undefined was not found on this server.
Apache/2.2.22 (Ubuntu) Server at 127.0.0.1 Port 80
what is wrong??
Flasheart
Re: zm not work
Post by Flasheart »
Zoneminder isn't installed correctly.
How to resolve depends a lot on your distribution, ZM version and how you installed it - from source or packages.
starwolf
Re: zm not work
Post by starwolf »
ubuntu 12.04
zoneminder 1.25.0-1 install from Synaptic
bb99
Re: zm not work
Post by bb99 »
Try reading this, maybe some clues. The sleep 15 is mandatory.
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
starwolf
Re: zm not work
Post by starwolf »
zm start but no more.
no camera no options
only first page
starwolf
Re: zm not work
Post by starwolf »
bengt@K73BY:~$ /etc/init.d/zoneminder restart
Stopping ZoneMinder: [sudo] password for bengt:
Zoneminder already stopped
Starting ZoneMinder: failure
bengt@K73BY:~$
What must i do?
have ubuntu 12.10
starwolf
Re: zm not work ubuntu 12.10
Post by starwolf »
no zoneminder in ubuntu 12.10?????????????????????????????????????????????
vanbosco
Post by vanbosco »
starwolf wrote:no zoneminder in ubuntu 12.10?????????????????????????????????????????????
You could give a try to this init.d script that wait mysql to start before starting zoneminder.
#!/bin/sh
### BEGIN INIT INFO
# Provides:          zoneminder
# Required-Start:    $network $remote_fs $syslog
# Required-Stop:     $network $remote_fs $syslog
# Should-Start:      mysql
# Should-Stop:       mysql
# Default-Start:     2 3 4 5
# Default-Stop:      0 1 6
# Short-Description:  Control ZoneMinder as a Service
### END INIT INFO
# description: Control ZoneMinder as a Service
# chkconfig: 2345 20 20
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
	echo -n "Starting $prog: "
#wait for mysql to start
	while [ ! -e /run/mysqld/mysqld.sock ]
 		do
 		sleep 1
	done
    zmfix -a
	$command start
	RETVAL=$?
	[ $RETVAL = 0 ] && echo success
	[ $RETVAL != 0 ] && echo failure
	echo
	[ $RETVAL = 0 ] && touch /var/lock/zm
	return $RETVAL
stop() {
	echo -n "Stopping $prog: "
	# Why is this status check being done?
	# as $command stop returns 1 if zoneminder
	# is stopped, which will result in
	# this returning 1, which will stuff
	# dpkg when it tries to stop zoneminder before
	# uninstalling . . .
	result=`$command status`
	if [ ! "$result" = "running" ]; then
		echo "Zoneminder already stopped"
		echo
		RETVAL=0
	else
		$command stop
		RETVAL=$?
		echo
		[ $RETVAL = 0 ] && rm -f /var/lock/zm
	fi
status() {
	if [ "$result" = "running" ]; then
		echo "ZoneMinder is running"
		RETVAL=0
	else
		echo "ZoneMinder is stopped"
		RETVAL=1
	fi
case "$1" in
'start')
	start
'stop')
	stop
'restart' | 'force-reload')
	stop
	start
'status')
	status
	echo "Usage: $0 { start | stop | restart | status }"
	RETVAL=1
esac
exit $RETVAL
In my ubuntu 12.10 zoneminder works with this script.
PatMcLJr
Post by PatMcLJr »
I have had great luck with these instructions and by far the easiest method of installing zoneminder that I have found
my box is only 32 bit but the guide still works very well
evil doers beware, someone is watching you,
hopefully me!
