Page 1 of 1
zm not work ubuntu 12.10
Posted: Sun Nov 04, 2012 4:51 am
by starwolf
i can login but
The requested URL /zm/undefined was not found on this server.
Apache/2.2.22 (Ubuntu) Server at 127.0.0.1 Port 80
what is wrong??
Re: zm not work
Posted: Sun Nov 04, 2012 6:53 am
by Flasheart
Zoneminder isn't installed correctly.
How to resolve depends a lot on your distribution, ZM version and how you installed it - from source or packages.
Re: zm not work
Posted: Sun Nov 04, 2012 6:28 pm
by starwolf
ubuntu 12.04
zoneminder 1.25.0-1 install from Synaptic
Re: zm not work
Posted: Mon Nov 05, 2012 1:18 am
by bb99
Try reading this, maybe some clues. The sleep 15 is mandatory.
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
Re: zm not work
Posted: Mon Nov 05, 2012 3:26 pm
by starwolf
zm start but no more.
no camera no options
only first page
Re: zm not work
Posted: Wed Nov 07, 2012 6:09 am
by starwolf
bengt@K73BY:~$ /etc/init.d/zoneminder restart
Stopping ZoneMinder: [sudo] password for bengt:
Zoneminder already stopped
Starting ZoneMinder: failure
bengt@K73BY:~$
What must i do?
have ubuntu 12.10
Re: zm not work ubuntu 12.10
Posted: Sun Nov 11, 2012 5:29 am
by starwolf
no zoneminder in ubuntu 12.10?????????????????????????????????????????????
Posted: Sun Dec 09, 2012 9:25 pm
by vanbosco
starwolf wrote:no zoneminder in ubuntu 12.10?????????????????????????????????????????????
You could give a try to this init.d script that wait mysql to start before starting zoneminder.
#!/bin/sh
### BEGIN INIT INFO
# Provides: zoneminder
# Required-Start: $network $remote_fs $syslog
# Required-Stop: $network $remote_fs $syslog
# Should-Start: mysql
# Should-Stop: mysql
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Control ZoneMinder as a Service
### END INIT INFO
# description: Control ZoneMinder as a Service
# chkconfig: 2345 20 20
# Source function library.
#. /etc/rc.d/init.d/functions
prog=ZoneMinder
ZM_PATH_BIN="/usr/bin"
command="$ZM_PATH_BIN/zmpkg.pl"
start() {
echo -n "Starting $prog: "
#wait for mysql to start
while [ ! -e /run/mysqld/mysqld.sock ]
do
sleep 1
done
zmfix -a
$command start
RETVAL=$?
[ $RETVAL = 0 ] && echo success
[ $RETVAL != 0 ] && echo failure
echo
[ $RETVAL = 0 ] && touch /var/lock/zm
return $RETVAL
stop() {
echo -n "Stopping $prog: "
# Why is this status check being done?
# as $command stop returns 1 if zoneminder
# is stopped, which will result in
# this returning 1, which will stuff
# dpkg when it tries to stop zoneminder before
# uninstalling . . .
result=`$command status`
if [ ! "$result" = "running" ]; then
echo "Zoneminder already stopped"
echo
RETVAL=0
else
$command stop
RETVAL=$?
echo
[ $RETVAL = 0 ] && rm -f /var/lock/zm
fi
status() {
if [ "$result" = "running" ]; then
echo "ZoneMinder is running"
RETVAL=0
else
echo "ZoneMinder is stopped"
RETVAL=1
fi
case "$1" in
'start')
start
'stop')
stop
'restart' | 'force-reload')
stop
start
'status')
status
echo "Usage: $0 { start | stop | restart | status }"
RETVAL=1
esac
exit $RETVAL
In my ubuntu 12.10 zoneminder works with this script.
Posted: Wed Dec 12, 2012 2:22 pm
by PatMcLJr
I have had great luck with these instructions and by far the easiest method of installing zoneminder that I have found
my box is only 32 bit but the guide still works very well
