I have been using an older release (1.22.3) and just recently that box crashed. So, I installed the newer 1.25 version.
With the newer version, I noticed that the Frames, Time Deltas now start at the 1st Pre-Event frame rather than the 1st Frame of the Alarm Event, like the older version did (1.22.3).
Specifically, I am triggering the start of the "event" using zmtrigger.pl.
Any idea why this changed and/or if there's a configuration to get this to work properly (like in 1.22.3)?
See attachments for the two comparisons in the time delta reporting.
Thanks for any help and/or information regarding this,
J.J.
Time Delta starts at Pre-Event start rather than at Alarm
- ZM 1.25 Frames incorrectly showing the start of the first Pre-Event as 0.00 Time Delta, rather than the first frame of the actual Alarm as Time Delta 0.00.
- ZM_1-25_FramesShowingFirstPreEventAsZeroDelta.png (23.86 KiB) Viewed 1029 times
- ZM 1.22.3 Frames correctly showing the start of the alarm (within the total event) as 0.00 Time Delta. Pre-Event frames are negative (as expected).
- ZM_1-22-3_FramesShowingAlarmEventAsZeroDelta.png (21.5 KiB) Viewed 1029 times
Re: Time Delta starts at Pre-Event start rather than at Alar
I guess a workaround solution to this is problem would be to post-process the Frames Table in the zm DB to recalculate the Delta after an Event completes.
Anyone have any idea how to fix this in the code and/or where it might be messing up?
Thanks for any help,
J.J.
J.J.
We had the exact same problem and couldn't figure out a way to fix it in the software itself so we wrote a trigger to basically do what you suggested. Here is the code if you'd like to use it in your environment:
USE zm;
DELIMITER $$
CREATE
DEFINER = 'zmuser'@'%'
TRIGGER update_endTime
AFTER UPDATE
ON Events
FOR EACH ROW
BEGIN
DECLARE inEventId INT(10);
DECLARE refDelta DECIMAL(8, 2);
DECLARE refFrameId INT(10);
DECLARE endTimeBool BOOLEAN;
SET inEventId = NEW.Id;
SELECT min(FrameId) FROM Frames WHERE Type = 'Alarm' AND EventId = inEventId INTO refFrameId;
SELECT count(*) FROM Events WHERE Id = inEventId AND EndTime IS NOT NULL INTO endTimeBool;
IF endTimeBool > 0 THEN
SELECT Delta FROM Frames WHERE EventId = inEventId AND FrameId = refFrameId INTO refDelta;
IF refDelta <> 0 THEN
UPDATE Frames SET Delta = Delta - refDelta WHERE EventId = inEventId;
END IF;
END IF;
END
DELIMITER ;
