I'm trying to add a usb webcamera into a working zoneminder (works for 4 IP-camera's).
I've got 3 different USB camera's connected to my Ubuntu server.
When i check on console:
zmu -d /dev/video0 -q -v -U admin -P admin -V1
Video Device: /dev/video0
Video Capabilities
Name: USB 2.0 Camera
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 0
Maximum Height: 0
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 320
Height: 240
Picture Attributes
Palette: 8 - YUYV
Colour Depth: 16
Brightness: 21959
Hue: 32768
Colour :44127
Contrast: 0
Whiteness: 39056
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Video Device: /dev/video2
General Capabilities
Driver: sn9c102
Card: SN9C1xx PC Camera
Bus: usb-0000:00:1a.2-2
Version: 1.1.47
Type: 0x5000001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Supports read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
Formats:
bayer rgb (BA81)
compressed (S910)
Crop Capabilities
Bounds: 640 x 480
Default: 640 x 480
Current: 640 x 480
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
zmu -d /dev/video3 -q -v -U admin -P admin -V1
Video Device: /dev/video3
Video Capabilities
Type: 1
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 640
Maximum Height: 480
Minimum Width: 48
Minimum Height: 32
Window Attributes
X Offset: 0
Y Offset: 0
Width: 640
Height: 480
Picture Attributes
Palette: 0 - Unknown
Colour Depth: 8
Brightness: 32896
Hue: 0
Colour :0
Contrast: 32768
Whiteness: 39321
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
So i've added 3 local camera's in zoneminder:
- Video0: dev/video0 - device channel 0 - device format PAL - device palette YUYV
- Video2: dev/video2 - device channel 0 - device format PAL - device palette RGB24
- Video3: dev/video3 - device channel 0 - device format PAL - device palette RGB24
This is the error i see in the logs (exit status 6)
tail -f zmdc.log
I've tried different setting in zoneminder (channel ID and ), but couldn't get them to work.11/06/2012 14:37:39.724149 zmdc[10324].INF [Starting pending process, zmc -d /dev/video0]
11/06/2012 14:37:39.724724 zmdc[10324].INF ['zmc -d /dev/video0' starting at 12/11/06 14:37:39, pid = 27149]
11/06/2012 14:37:39.758369 zmdc[10324].WAR [Can't find process with command of 'zma -m 6']
11/06/2012 14:37:39.886703 zmdc[10324].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
11/06/2012 14:37:44.060793 zmdc[10324].INF [Starting pending process, zmc -d /dev/video0]
11/06/2012 14:37:44.061523 zmdc[10324].INF ['zmc -d /dev/video0' starting at 12/11/06 14:37:44, pid = 27207]
11/06/2012 14:37:44.220205 zmdc[10324].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
11/06/2012 14:37:54.040100 zmdc[10324].INF [Starting pending process, zmc -d /dev/video0]
11/06/2012 14:37:54.040851 zmdc[10324].INF ['zmc -d /dev/video0' starting at 12/11/06 14:37:54, pid = 27496]
11/06/2012 14:37:54.206279 zmdc[10324].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
11/06/2012 14:38:14.035965 zmdc[10324].INF [Starting pending process, zmc -d /dev/video0]
11/06/2012 14:38:14.036754 zmdc[10324].INF ['zmc -d /dev/video0' starting at 12/11/06 14:38:14, pid = 28050]
11/06/2012 14:38:14.201500 zmdc[10324].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
11/06/2012 14:38:44.074618 zmdc[10324].INF [Starting pending process, zmc -d /dev/video3]
11/06/2012 14:38:44.075344 zmdc[10324].INF ['zmc -d /dev/video3' starting at 12/11/06 14:38:44, pid = 28802]
11/06/2012 14:38:44.075628 zmdc[10324].INF [Starting pending process, zmc -d /dev/video2]
11/06/2012 14:38:44.076041 zmdc[10324].INF ['zmc -d /dev/video2' starting at 12/11/06 14:38:44, pid = 28803]
11/06/2012 14:38:44.147870 zmdc[10324].ERR ['zmc -d /dev/video2' exited abnormally, exit status 6]
11/06/2012 14:38:44.175350 zmdc[10324].ERR ['zmc -d /dev/video3' exited abnormally, exit status 6]
11/06/2012 14:38:54.095285 zmdc[10324].INF [Starting pending process, zmc -d /dev/video0]
11/06/2012 14:38:54.096023 zmdc[10324].INF ['zmc -d /dev/video0' starting at 12/11/06 14:38:54, pid = 28982]
11/06/2012 14:38:54.271569 zmdc[10324].ERR ['zmc -d /dev/video0' exited abnormally, exit status 6]
11/06/2012 14:39:52.068835 zmdc[10324].INF [Starting pending process, zmc -m 1]
Any idea what else i can do?
