Constant deleting of orphaned frame records..
themagicm
Post by themagicm »
I've noticed recently that it takes a long time to actually log into ZM. After looking at /var/log/messages, I see shows up in my log file every second.. How do I fix that?
Nov 12 08:32:46 magicserver zmaudit[3052]: INF [deleting]
Nov 12 08:32:46 magicserver zmaudit[3052]: INF [Found orphaned frame records for event '18424']
Nov 12 08:32:46 magicserver zmaudit[3052]: INF [Found orphaned frame records for event '18423']
themagicm
Re: Constant deleting of orphaned frame records..
Post by themagicm »
bueller...bueller...anyone......anyone?
ZM is practically useless at this point. Too slow.
themagicm
Post by themagicm »
Is there a replacement for this software? 1.25 blows.
PacoLM
Post by PacoLM »
Check if you have a filter that is consistenly deleting the filters for any reason. In my case I have a filter that is deleting events with low duration or a number of alarm frames lower than 5. I get this kind of messages from time to time.
Hope it helps,
PacoLM
themagicm
Post by themagicm »
No filters.
I started looking at it.. I basically kill -9 zmaudit and now it runs great. So I restarted zm and zmaudit was still running, but I guess that took care of it? weird.
