zm 1.25 does not start correctly and does not show load
sipi
Post by sipi »
Hi, I tried latest 1.25 from liquid-co.de opensuse repo and I have some problem on opensuse 12.1 x86_64.
1st. zm does not show system (cpu?) load in upper right corner but shows disk usage.
2nd. zm can't start correctly: if I start it systemctl or from init.d then status info shows it runs but zm console shows it does not run... If I start zm from zm console then it can start. If I setup in Yast or systemctl that zm starts on boot it does not work I need start it manually by zm console....
Do you have some advice or help? Thanks.
sipi
Re: zm 1.25 does not start correctly and does not show load
Post by sipi »
I could to fix that zm 1.25 can show system load. Thanks Monex by your help. He is the opensuse zoneminder rpms maintainer/creater.
He advised that I change includes/functions.php on zm webdir. Here his advice:
"It is because the uptime
command now is localized and the webfrontend looks out for the keyword
'average' but when you type uptime there is something different
displayed depending on your language settings. As a workaround edit:
includes/functions.php line 2436 and change:
$uptime = shell_exec( 'uptime' );
to
$uptime = shell_exec( 'LC_ALL="EN_en" uptime' );
If this works for you too I will add this to the RPM."
Thanks Monex.
sipi
Post by sipi »
Sorry, there was an error.
The correct text is:
... LC_ALL="en_EN" ...
