zm 1.25 does not start correctly and does not show load
Posted: Tue Nov 13, 2012 10:09 am
Hi, I tried latest 1.25 from liquid-co.de opensuse repo and I have some problem on opensuse 12.1 x86_64.
1st. zm does not show system (cpu?) load in upper right corner but shows disk usage.
2nd. zm can't start correctly: if I start it systemctl or from init.d then status info shows it runs but zm console shows it does not run... If I start zm from zm console then it can start. If I setup in Yast or systemctl that zm starts on boot it does not work I need start it manually by zm console....
Do you have some advice or help? Thanks.
