Page 1 of 1
Unable to probe network cameras, status is '127'
Posted: Wed Nov 14, 2012 8:29 pm
by Axxel
Hi everybody :D
I'm running on Ubuntu 12.04.1 LTS with ZM 1.25.0 and with a video capture card a base de chip BT878.
My video-capture card works perfectly with v4l2 using VLC I can have the video preview with this command line:
vlc v4l2:///dev/video0:input=1
I installed ZoneMinder sucessfully and I get a problem when I try to probe the camera :
So I looked after information and I found this fix :
#Si se agrega un nuevo monitor o se modifica un existente y se quiere usar la funcion Probe muestra un error: Unable to probe network cameras, status is '127'
#Para solucionar el error editamos como root el archivo /skins/classic/views/monitorprobe.php y buscamos la linea $command = "arp -a";
#Esa linea se sustituye con: $command = "/usr/sbin/arp -a";
#Ya debe funcionar Probe.
I modified the monitorprobe.php file, and I follow to get the same error.
I tried the command /usr/sbin/arp -a into a terminal and I get this result (it sould be correct) :
hn-server@hn-server:/usr/share/zoneminder/skins/classic/views$ /usr/sbin/arp -a
Axxel-PC.home (192.168.1.112) en 90:e6:ba:22:a6:e3 [ether] en eth0
livebox.home (192.168.1.1) en 98:8b:5d:3d:7a:85 [ether] en eth0
I tried to restart the ZM Service with
sudo service zoneminder restart
The ZM service stops correctly ans starts correctly without any error message.
I looked after this post : http://www.zoneminder.com/forums/viewto ... obe#p74901
and this post http://www.zoneminder.com/forums/viewto ... obe#p75814
and I couldn't find anything which can help mi to solve the problem :(
Please help me!
Best regards.
