I'm new in ZoneMinder world and I have a problem.
My system is a Linux Ubuntu OS with ZoneMinder 1.24.2 and now I have just a Foscam IP Outdoor linked in ZoneMinder.
I have a problem with the zone detection.
When I use the default zone everythings going right, but I try to reduse to a layer the space detection (more or less 10 % of visible space) but the motion trigger start also if somethings move out of the zone.
I try some preset configuration like "Fast, low sensitivity" and so on but no change.
Someone have this problem? Anyone have resolved this problem?
thanks
Zone detection problem
Re: Zone detection problem
It seams like cyclic.
If you see the attach image, the event are cyclic like: every 5 - 20 - 36 - 52 in a minut ZoneMinder triggers an event
- screen
- Screenshot.jpg (101.35 KiB) Viewed 2568 times
Find a solution or work around.
I define multi zone to cover all image, and I set "Inactive" for all zone than I don't want a motion detection.
