H264 CCTV 1280*720 dont work with ZoneMinder
Posted: Sat Nov 17, 2012 12:44 pm
Hye
Sorry for my english i'm french....
I Have buy a camera H264 720p in china.
This Model
cgi.ebay.fr/Newest-HD-1MP-H-264-Mjpeg-PT-wireless-wifi-Ip-Camera-With-Ir-Cut-SD-card-slot--/180986970329?pt=US_Security_Cameras&hash=item2a23aa00d9
I have found the command :
IPaddress:port/snapshot.cgi
IPaddress:port/videostream.cgi
IPaddress:port/stream.htm
IPaddress:port/streaminfo.htm
RTSP stream rtsp://login:password@IPaddress:port
MJPEG stream IPaddress:port/videostream.cgi?user=login&password=******
asf stream IPaddress:port/videostream.asf?user=login&password=******
snapshot IPaddress:port/snapshot.jpg?user=login&password=******
snapshot.jpg can also written as snap.cgi,snap.jpg or snapshot.cgi
htttp://IPaddress:port:port/videostream.asf?user=admin&password=admin
But, I add a monitor, it ok if the resolution is 640*480.
But then i put 1280*720, zm dont connect to my camera.
I Use remote, modect, http, simple, host name : the ip camera and host path /videostream.cgi?user=admin&pwd=admin
That is the solution for 720p?
Tks
This Model
Tks
