ZM 1.25.0 RTSP camera problem
morgan
Post by morgan »
I have problem event videos, it's happend permanently sometimes I can watch video Zoneminder 1.25.0 CentOS 6.3 x64
zmc_m1 3313 INF Priming capture from rtsp://login:password@xxx.xxx.xxx.xxx:port/video zm_ffmpeg_camera.cpp 91
zmc_m1 3313 INF Starting Capture zmc.cpp 191
zmdc 3313 INF 'zmc -m 1' started at 12/11/23 00:13:23 zmdc.pl
zmdc 3156 INF 'zmc -m 1' starting at 12/11/23 00:13:23, pid = 3313 zmdc.pl
zmdc 3156 INF Starting pending process, zmc -m 1 zmdc.pl
web_php 2588 ERR socket_sendto( /tmp/zm/zms-844162s.sock ) failed: Connection refused zm/includes/functions.php 2322
zms 3309 INF addr2line -e /var/www/cgi-bin/zms() 0x3c4b20f500 0x3c4ae328a5 0x3c4ae34085 0x414462 0x4441ee 0x41c529 0x41cf42 0x407046 0x3c4ae1ecdd 0x406079 zm_signal.cpp 127
zms 3309 INF Backtrace complete, please execute the following command for more information zm_signal.cpp 126
zms 3309 ERR Backtrace: /var/www/cgi-bin/zms() [0x406079] zm_signal.cpp 123
zms 3309 ERR Backtrace: /lib64/libc.so.6(__libc_start_main+0xfd) [0x3c4ae1ecdd] zm_signal.cpp 123
zms 3309 ERR Backtrace: /var/www/cgi-bin/zms() [0x407046] zm_signal.cpp 123
zms 3309 ERR Backtrace: /var/www/cgi-bin/zms() [0x41cf42] zm_signal.cpp 123
zms 3309 ERR Backtrace: /var/www/cgi-bin/zms() [0x41c529] zm_signal.cpp 123
zms 3309 ERR Backtrace: /var/www/cgi-bin/zms() [0x4441ee] zm_signal.cpp 123
zms 3309 ERR Backtrace: /var/www/cgi-bin/zms() [0x414462] zm_signal.cpp 123
zms 3309 ERR Backtrace: /lib64/libc.so.6(abort+0x175) [0x3c4ae34085] zm_signal.cpp 123
zms 3309 ERR Backtrace: /lib64/libc.so.6(gsignal+0x35) [0x3c4ae328a5] zm_signal.cpp 123
zms 3309 ERR Backtrace: /lib64/libpthread.so.0() [0x3c4b20f500] zm_signal.cpp 123
zms 3309 ERR Signal address is 0x206, no eip zm_signal.cpp 91
zms 3309 INF Got signal 6 (Aborted), exiting and forcing backtrace zm_signal.cpp 65
zms 3309 PNC Could not open codec zm_mpeg.cpp 181
zms 3309 WAR Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results zm_monitor.cpp 439
zms 3309 INF Authenticated user 'admin' zm_user.cpp 136
zmdc 3156 ERR 'zmc -m 1' exited abnormally, exit status 255 zmdc.pl
zmc_m1 3293 ERR Failed to capture image from monitor 1 (0/1) zmc.cpp 263
zmc_m1 3293 ERR Unable to read packet from stream 0: error -1 zm_ffmpeg_camera.cpp 166
zmc_m1 3293 INF Priming capture from rtsp://login:password@xxx.xxx.xxx.xxx:port/video zm_ffmpeg_camera.cpp 91
zmc_m1 3293 INF Starting Capture zmc.cpp 191
zmdc 3293 INF 'zmc -m 1' started at 12/11/23 00:10:53 zmdc.pl
zmdc 3156 INF 'zmc -m 1' starting at 12/11/23 00:10:53, pid = 3293 zmdc.pl
zmc_m1 3282 ERR Failed to capture image from monitor 1 (0/1) zmc.cpp 263
zmc_m1 3282 ERR Unable to read packet from stream 0: error -1 zm_ffmpeg_camera.cpp 166
henke
Re: ZM 1.25.0 RTSP camera problem
Post by henke »
I am seeing the same error with an AXIS M1054 trying to use h.264 with the url:
@192.168.80.109:554/axis-media/media.amp
Did you find a solution for it?
DenisBY
Post by DenisBY »
same error with hikvision camera. but ffmpeg reports normal output:
$ ffprobe rtsp://10.0.4.1:554//Streaming/Channels/1
avprobe version 0.8.6-4:0.8.6-0ubuntu0.12.04.1, Copyright (c) 2007-2013 the Libav developers
built on Apr 2 2013 17:02:36 with gcc 4.6.3
[rtsp @ 0x1d1b7a0] Estimating duration from bitrate, this may be inaccurate
Input #0, rtsp, from 'rtsp://10.0.4.1:554//Streaming/Channels/1':
Metadata:
title : Media Presentation
Duration: N/A, start: 0.003644, bitrate: N/A
Stream #0.0: Video: h264 (Main), yuv420p, 1920x1080, 25 fps, 45k tbr, 90k tbn, 50 tbc
I have version 1.26
bysard
Post by bysard »
I'm seeing similar problems with Astrind IP cameras. I have no problem viewing/capturing stream in Windows or avconv in Linux. In Zoneminder 1.25 I only see this spam in logs and nothing else:
2013-10-01 14:45:33.478865 zmc_m3 6432 ERR 256: 7c 81 ec 06 c5 0a 3f 3d 58 5f fc 99 ca c6 41 f7 de 18 09 3d c0 6f f0 c3 c9 58 4d e7 89 98 00 56 81 d9 40 ac 01 0e 86 15 02 df a0 fc 7d 80 93 0e 20 db 40 65 1a 86 95 15 cf 08 35 c7 6f fb 41 4e 82 a3 f2 4f f9 84 1f 08 73 54 c3 f0 9b 8e ed e0 96 00 d2 4 zm_remote_camera_rtsp.cpp 225
2013-10-01 14:45:33.478350 zmc_m3 6432 ERR Error while decoding frame 0 zm_remote_camera_rtsp.cpp 224
2013-10-01 14:45:33.305390 zmc_m3 6432 ERR 256: 7c 81 ea 07 c5 0a f0 94 ce ae bc 6d 3d 72 f1 d4 1f 86 e7 e3 09 1d 7f b1 f9 34 91 9a be 7a b0 26 04 df fc f5 b0 bf f0 8e 34 64 d1 b6 0f 5e 44 03 f1 be 81 98 64 f6 29 f1 9a 80 8d e8 ef 3c d3 d8 57 38 60 2a c2 d2 87 9c b9 8a 01 96 9b e7 45 e3 28 d0 3e 6 zm_remote_camera_rtsp.cpp 225
2013-10-01 14:45:33.304963 zmc_m3 6432 ERR Error while decoding frame 0 zm_remote_camera_rtsp.cpp 224
2013-10-01 14:45:33.104724 zmc_m3 6432 ERR 256: 7c 81 e8 06 c5 0a f3 e2 fa 2a 26 3f 3d 7b 02 ff 0e 5b 1a a7 5f b2 fc 39 22 90 8f 02 9c d1 cb 40 3f 45 5c 27 1d 0b 3e 78 f1 fb 9e 1a e4 61 57 f9 1f e3 78 d7 dd 09 87 a1 eb 99 7d f7 1b 22 d8 bd ff ae 53 36 b0 be 15 e1 11 c0 86 9d 2e 00 b8 21 28 68 a0 6 zm_remote_camera_rtsp.cpp 225
2013-10-01 14:45:33.104290 zmc_m3 6432 ERR Error while decoding frame 0 zm_remote_camera_rtsp.cpp 224
2013-10-01 14:45:32.899926 zmc_m3 6432 ERR 256: 7c 81 e6 04 c5 0a f0 e6 b3 30 bd ff cf 5e 87 eb 92 eb 69 73 d7 ef f9 b0 bb ef e1 6e 0c 6f 4a 77 df 5d 87 ff 78 25 7c b7 cd 40 38 f9 27 25 01 a6 38 15 7c 21 28 4a 82 a0 31 81 01 ae 37 a0 90 43 b8 a5 4a 07 41 6a 63 47 e3 70 e4 18 3d 60 18 7f 87 5a e7 c zm_remote_camera_rtsp.cpp 225
2013-10-01 14:45:32.899482 zmc_m3 6432 ERR Error while decoding frame 0 zm_remote_camera_rtsp.cpp 224
2013-10-01 14:45:32.706585 zmc_m3 6432 ERR 256: 7c 81 e4 0f 14 28 dc f5 a1 7e b9 61 1f 27 e3 eb 9b 37 b3 7c 21 c3 cb d9 c6 d6 1c 03 64 a8 1d 47 00 0e d4 74 19 83 93 ed 72 ec d8 0c 74 0f fc 5e 60 d0 44 d3 18 e0 2c 26 60 9e 4d 1c 3f cd 5e af 3e af 90 a3 ac af be 6a 67 cd 73 5d ed 79 6b 77 13 c8 48 7 zm_remote_camera_rtsp.cpp 225
2013-10-01 14:45:32.706132 zmc_m3 6432 ERR Error while decoding frame 0 zm_remote_camera_rtsp.cpp 224
2013-10-01 14:45:32.504021 zmc_m3 6432 ERR 256: 7c 81 e2 0b 14 2b c5 78 0e 00 95 19 32 0e 00 97 11 32 0e 00 97 11 33 cd 84 6c 4b 5d 71 5e 03 89 c9 32 0b bd 27 ea 0e 2d 24 c5 c3 30 03 82 89 de 83 4f 07 f5 fe eb 93 1d 02 da 76 59 70 9f 87 d3 f7 9c f4 08 3f 01 fe 99 f0 9d 33 2e 18 5e 2a 13 03 38 70 2 zm_remote_camera_rtsp.cpp 225
Any help apreciated.
br,
bysaRD
