Foscom FI8602W configuration
abstar6
Post by abstar6 »
I have recently acquired Foscom FI8602W and trying to setup in zoneminder without joy.
I have installed zoneminder on ubuntu server 12.04, I can access zoneminder via server_ip/zm ok.
I have also followed the instructions without joy - zoneminder wiki for Foscam_FI8602W
Any help will be appreciated
verbeke
Re: Foscom FI8602W configuration
Post by verbeke »
Did you use the correct Capture Height and Width.
If u use the settings provided on the zoneminder wiki for the Foscam FI8602W it will not work.
You have to use these settings:
Capture Width : 704
Capture Height : 576
abstar6
Post by abstar6 »
Appreciate your help verbeke,
I changed the settings to your recommendation and that seems to work brilliantly.
General
Source Type: Ffmpeg
Source
Source Path: rtsp://username:password@x.x.x.x/11
Width: 704
Height: 576
Now it's time to have fun customization, any help and tricks will be highly welcome.
esantillan
Post by esantillan »
Hi, I bought the same camera and I entered the same values, and it is not working for me, it does not display any video, and the camera name is in red, like not available, Can you please tell me the settings you used in the camera?
