Help configuring ZM with one CAM and different popositions
Posted: Fri Nov 30, 2012 1:36 pm
I have an IP motorized Camera (FOSCAM generic). I configured it successfully in ZM. Now as far as it is motorized i'd like to configure different point of view so i can schedule the zone which is monitored with different detection zones and different parameters and i can track movement from a zone to another.
My first idea was to create two monitors for each CAM position (one for initializing position and second for motion detect) and to schebule change betwwen position with crontab and ZM runstates.
Camera position can be controlled by sending an URL like <IP>/decoder_control.cgi?command=nn (nn is the preset position) so i created a first monitor in monitor mode with this control url for cam initialization and another one in MODECT mode and i created another couple of monitors for another cam position.
Unfortunately it doesn't work and cam switch from one position to another.
If you have any tip or idea about it, it should be really helpfull for me.
Thanks for your help.
Raph.
Raph.
