Problem with LifeCam HD-5000 and Creative Live! Cam Vista I
ktc.ldz
Post by ktc.ldz »
ZoneMIndera installed on Debian, version 6.0.6.
ZoneMinder looks like it is working correctly, the problem occurs when you try to connect a USB camera.
I have two cameras on "interfaces":
video1 Creative Live! Cam Vista IM
video0 Microsoft® LifeCam HD-5000
I hope I can watch the two webcam programs such as Luvcview, guvcview, etc ...
Cams work themselves, they are installed properly, they can be "controlled" white balance, contrast ......
Despite everything, they do not want to hook up with ZoneMinderem, instead of the camera image shows a black screen in the browser - and the path to the camera in red .....
the command
# zmu -d /dev/video0 -q -v
________________________________
Video Device: /dev/video0
General Capabilities
Driver: uvcvideo
Card: Microsoft® LifeCam HD-5000
Bus: usb-0000:00:1d.7-8
Version: 0.1.0
Type: 0x4000001
Supports video capture (X)
Does not support video output
Does not support frame buffer overlay
Does not support VBI capture
Does not support VBI output
Does not have tuner
Does not have radio
Does not support read/write i/o (X)
Does not support async i/o
Supports streaming i/o (X)
Standards:
Formats:
YUV 4:2:2 (YUYV) (YUYV)
MJPEG (MJPG)
Crop Capabilities
Bounds: 800 x 448
Default: 800 x 448
Current: Cropping is not supported
Inputs: 1
Input 0
Type: Camera
Audioset: 00000000
Standards: 0x0
Power on (X)
Signal detected (X)
Colour Signal detected
Horizontal Lock detected
_________________________________
Has anyone met this problem, I searched the internet and have not found any working solution ???
HELP :-)))????
