Problem with distorted picture
augustynr
Post by augustynr »
I have installed the 1.25 version by compiling with ffmpeg.
Now all works well for a while and then I get a very distorted pics.
Please look at the attached pic.
What could be the reason for this?
My settings are:
Source type ffmpeg
Source path: rtsp://192.168.2.242:554
It is grandstream GXV3611HD
btw: the pic looks ok in Grandstream tools.
acidke
Re: Problem with distorted picture
Post by acidke »
Hello
I have exactly the same issue. Any help would be appreciated. Strange thing is, when opening the stream in VLC, there are no issues.
When using low resolution / bitrate, the stream is ok in zoneminder too.
Operating system is ubuntu 12.04 LTS.
Thanks for your help.
augustynr
Post by augustynr »
Can you try to lower the resolution and run it again?
