I have Zoneminder 1.25.
On the web console when I click on some event I only have these "tabs"
Delete Edit Export Archive Frames Stills
and no Video.
On other server (everything the same) I have Video "tab" also!
I've searched the web to find itbut no results - please tell me how to enable it?
Thank you!
No video tab on Events
Re: No video tab on Events
I had this problem too.
Go to options, images tab.
Make sure the "Is the ffmpeg video encoder/decoder installed" cheked.
Also make sure ffmpeg is installed and the path is correct.
Second what theforce just said.
If you're running Ubuntu server and did the apt-get install ffmpeg is /usr/bin/ffmpeg
