Only needed to comment out one line in /etc/httpd/httpd.conf
LoadModule cgi_module lib/httpd/modules/mod_cgi.so
Now able to stream video real time in monitors.
I can only see individual images in the "stills", but cannot stream. I have not been able to get streaming video under "monitor" or "modect".
Cambozola is enabled under options, but IE9 nor Firefox 17 able stream video.
Had to compile slightly older FFMPEG to get ZM1.25 to build.
ZM Docs says you need ffmpeg-devel to build correctly. I can't find this package anywhere. Here's what's installed:
ffmpeg version 0.10.6 Copyright (c) 2000-2012 the FFmpeg developers
built on Dec 12 2012 19:57:22 with gcc 4.7.1
configuration: --prefix=/usr --libdir=/usr/lib --shlibdir=/usr/lib --mandir=/usr/man --disable-debug --enable-shared --disable-static --enable-pthreads --enable-libtheora --enable-libvorbis --enable-gpl --enable-version3 --enable-postproc --enable-swscale --enable-x11grab --enable-avfilter --enable-gnutls --enable-libcdio --arch=i486 --enable-libmp3lame --enable-libx264
libavutil 51. 35.100 / 51. 35.100
libavcodec 53. 61.100 / 53. 61.100
libavformat 53. 32.100 / 53. 32.100
libavdevice 53. 4.100 / 53. 4.100
libavfilter 2. 61.100 / 2. 61.100
libswscale 2. 1.100 / 2. 1.100
libswresample 0. 6.100 / 0. 6.100
libpostproc 52. 0.100 / 52. 0.100
Hyper fast Audio and Video encoder
usage: ffmpeg [options] [[infile options] -i infile]... {[outfile options] outfile}...
:/tmp/zm# ls -l
total 0
srwxr-xr-x 1 apache apache 0 Dec 13 08:21 zmdc.sock=
