Wavy Image on One Channel
Posted: Mon Dec 24, 2012 8:03 pm
Hello all:
I have attached in image of what is occurring on the fourth channel of my Zoneminder setup.
I have tried four different cameras. When any of the cameras are connected directly into the PV-143 card, with a 3 foot cable, the image is perfect.
However, when I connect it as you can see in the attached image, the image becomes "wavy". In the attached picture, it is running through a 50ft. cable.
Is the problem with the length of my cable? Or is the cable itself likely damaged?
Please note, the camera I am using on channel four is an older Panasonic analog b&w camera running at 24v AC. My other three images working perfectly are newer Q-See cameras running at 12v DC.
Thanks for your help!
