Page 1 of 1
Mocord Video - Start Fram
Posted: Fri Jan 04, 2013 4:09 am
by ahuberpsu
I'm very new to the zoneminder software so this may be a newbie question.
I'm currectly in mocord. 10 minute (hardcoded?) intervals are captured and after motion occurs it creates a separate event. I then use an event filter to send an email with the video footage of this.
Problem: sometimes this video is 9:40 seconds long and only has 3 seconds of footage worth anything at the very end.
Two questions which may help me solve the issue.
Question 1: Can I capture only the 3 seconds of footage to send an email as a video? Ie, define the filter to capture mpeg only on active alarm (pre/post alarm) frames.
Question 2: Can I define a filter to act on an "Alarm" and the frames it pertains to, as opposed to an event which may be a continuous record event?
Thanks.
