BobS0327
Post Re: Which ports to open for remote access
I'm using a Linksys E2500 router. My remote management Access option is disabled. I also had to uncheck Filter Anonymous Internet Requests in the Security tab of my router to get remote access to ZM.
Yep, I had to do what Paco recommended. It's been a while since I did this but if memory serves me correctly I had to add an entry for port 8080 to /etc/apache2/ports.conf and I had to create a virtual host for 8080 in /etc/apache2/sites-enabled/000-default.
Finally I had to sudo ufw allow 8080
Doing all this allowed me to use port 8080 to remotely access ZM.
i found this on forum the solution incase anyone got stuck like i was.
