I like to use rstp for some ip cam's but the log shows:
zmc_m2[29001]: FAT [You must have ffmpeg libraries installed to use remote camera protocol 'rtsp' for monitor 2]
I rebuild zoneminder and rebuild ffmpeg/x264 and added
--with-ffmpeg \
--with-extralibs="`pkg-config --libs libavcodec libavdevice libavfilter libavformat libavutil libpostproc libswscale`" \
CPPFLAGS=-D__STDC_CONSTANT_MACROS \
to the configure lines in zoneminder.spec and it complies fine running rpmbuild --clean -ba zoneminder.spec
part of the output:
checking libavutil/avutil.h usability... yes
checking libavutil/avutil.h presence... yes
checking for libavutil/avutil.h... yes
checking libavcodec/avcodec.h usability... yes
checking libavcodec/avcodec.h presence... yes
checking for libavcodec/avcodec.h... yes
checking libavformat/avformat.h usability... yes
checking libavformat/avformat.h presence... yes
checking for libavformat/avformat.h... yes
checking libswscale/swscale.h usability... yes
checking libswscale/swscale.h presence... yes
checking for libswscale/swscale.h... yes
Running: Fedora 17 x86_64
Using zoneminder-1.25 source RPM patchlevel 10 for Fedora 19 and
ffmpeg-devel-0.10.6-1.fc17.x86_64, ffmpeg-0.10.6-1.fc17.x86_64 and ffmpeg-libs-0.10.6-1.fc17.x86_64 rebuild them against x264 libraries
Any suggestions?
Still no RSTP due to missing ffmpeg libraries
Re: Still no RSTP due to missing ffmpeg libraries
Hi Marcnl,,
I am having the same trouble using Ubuntu 12.04 64 server.
Spending a week on reading in the forum and googling,,,, ( got squary eyes ) regarding a message in ZM log "You must have ffmpeg libraries installed to use ffmpeg cameras"
I did compile ZM from SVN several times following hints which I did find in the forum,,, at the end,,, no luck.
Looking at all the entries regarding this specific problem , I seems to me that I am not the only one.
Did you find a solution to your problem ?
Cheers
Cheers
